Oh almost forgot, i just picked up my headers and y pipe i had ceramic coated and xmc coated on the inside. suppose to be up to 70% cooler than an un coated pipe. i guess i will find out soon enough
klze swap
Well got some pics of the ac bolted to the motor with the protege line attached. im posting this for anyone else that wants to put in a v6 and have ac. the line is very close but not touching. in the pic it looks like there is no space but indeed there is. Also cleaned primed and painted the lower mount crossmember91 protege gt. dropzone mx3 springs, mx3 crossmember, ractive front and rear strut braces, rear lower mx3 brace, 4 wheel disc brakes, corksport ss brake and clutch lines,kvr front pads, ractive cai,ram air hood scoop, modified front bumper, shaved ant and rear trunk lock, fubu ant, short shifter, corksport bronzeoil shifter bushings,92 glass sunroof and tail lights, mx3 center console, autometer gauges (volt and oil pressure) cluster needles painted to match, sound system, 17 inch eagle alloy 193 with 205 40 17 rubber. klze is ALIVE BABY!! . http://www.cardomain.com/ride/2394656http://www.toprotege.com/forums/show...hlight=project[url]
let me know if you need some random v6 parts, i still have a misc pile of them.---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
Nice clean work, this is going to turn into a little screamer'90 Mazda 323 - V6 KLDE, supercharged, right-hand drive, build log
nice man! this is gonna be sick! this is something i've been wanting/trying to do for years. ze swap in a protege! i was super close too, mx3 parts car and all haha.
JACK-Jack
looking VERY NICE sir!---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
What rad will you be using?? Nice work by the wayDominic Toretto rocks a MaZda and his cell phone number starts in "(323)"
thanks guys, on the rad front im not too sure yet. have some ideas but i will see as i go along. Should be at that point in the near future.91 protege gt. dropzone mx3 springs, mx3 crossmember, ractive front and rear strut braces, rear lower mx3 brace, 4 wheel disc brakes, corksport ss brake and clutch lines,kvr front pads, ractive cai,ram air hood scoop, modified front bumper, shaved ant and rear trunk lock, fubu ant, short shifter, corksport bronzeoil shifter bushings,92 glass sunroof and tail lights, mx3 center console, autometer gauges (volt and oil pressure) cluster needles painted to match, sound system, 17 inch eagle alloy 193 with 205 40 17 rubber. klze is ALIVE BABY!! . http://www.cardomain.com/ride/2394656http://www.toprotege.com/forums/show...hlight=project[url]
I am thinkin' a Probe GT rad for my KLZE 323. I had it in the back of my mind I could use the MX-3 V6 rad if i modified the rad support. I test fit it, not freakin' likely LOL. The MX-3 V6 rad fit like a 10 pound square peg in a 3 pound round hole.Dominic Toretto rocks a MaZda and his cell phone number starts in "(323)"
i might try a civic half rad, but i would like a larger rad in there. im using the a/c so i dont have the option to shove the rad in the rad support in the condensor area. someone around these parts used a neon rad but im going to search out some other options. at one point i thought about the mx-3 rad but no dice.91 protege gt. dropzone mx3 springs, mx3 crossmember, ractive front and rear strut braces, rear lower mx3 brace, 4 wheel disc brakes, corksport ss brake and clutch lines,kvr front pads, ractive cai,ram air hood scoop, modified front bumper, shaved ant and rear trunk lock, fubu ant, short shifter, corksport bronzeoil shifter bushings,92 glass sunroof and tail lights, mx3 center console, autometer gauges (volt and oil pressure) cluster needles painted to match, sound system, 17 inch eagle alloy 193 with 205 40 17 rubber. klze is ALIVE BABY!! . http://www.cardomain.com/ride/2394656http://www.toprotege.com/forums/show...hlight=project[url]
Well got all the suspension in, spindles, struts, cv axles, brakes, power steering lines, wiring, shifter linkages and wheels. Woohoo shes a roller again. threw a batt in there to see if i was lucky to have a starting motor. turn the key start cranking woohoo......and then no start. i got fuel but no spark. kind of figured that so now i have to get a few good wiring diagrams to sort out the mess. From what i have been able to see so far there are a lot of wires in different locations and about 4 wires to the fuse box that go nowhere. so now its time to trace. here is a few pics of how it currently sits.91 protege gt. dropzone mx3 springs, mx3 crossmember, ractive front and rear strut braces, rear lower mx3 brace, 4 wheel disc brakes, corksport ss brake and clutch lines,kvr front pads, ractive cai,ram air hood scoop, modified front bumper, shaved ant and rear trunk lock, fubu ant, short shifter, corksport bronzeoil shifter bushings,92 glass sunroof and tail lights, mx3 center console, autometer gauges (volt and oil pressure) cluster needles painted to match, sound system, 17 inch eagle alloy 193 with 205 40 17 rubber. klze is ALIVE BABY!! . http://www.cardomain.com/ride/2394656http://www.toprotege.com/forums/show...hlight=project[url]
