where's the pics?
Toyota E153 transmission swap
Moving up would be better then forward but how will that work with hood clearance?I live my life a quarter pounder at a time. And for those 500 calories or more, I'm free. I need FRIES! Two of them. The big ones. Oh, and I need them tonight. You're lucky the double shot of BBQ sauce didn't blow the seam on your nugget box. There she is, 2 pounds of pure beef. My dad ate it in 9.0 seconds flat. Check it out, it's like this. If I lose, winner takes my happy meal. But if I win, I take the burger and the toy. To some people, that's more important.
._________________________
well adjusting the exhaust is no biggie as i am cutting out a straight section to add a resonator anyway. the shifter is a cable linkage, so there is plenty of room to go up, down, left, right, etc
we are building all four mounts and a new crossmember anyway, regardless of whether or not we go forward or up. thinking about it again i may actually have to do a little of both. the inner cv joints are interfering with those vertical gusset parts of the k-frame.
anyway i'm uploading some pics nowEscort GTR -- 11.87 @ 117.6 mph -- 320 HP / 325 Ft. Lbs. @ 23 PSI
the car as it arrived at the shop
getting the plate bolted up to the trans... cutting bolts to length etc.
here you can see the clearance notch for the starter. ended up a little bigger than i hoped, but we will make a nice cover to hide it later (or maybe a scatter shield)
clearance notch for plate to engine bolt head
tada! it fits together
back side
another angle
making the intermediate shaft bracket (re-using original MR2 bracket)
voila! 3/8" plate steel, shouldnt go anywhere...
this is a shot of the initial drop-in. a groundbreaking moment in mazda tuning in the US?
better angle
heating and hammering the frame rail. the trans just about fit where it needed to go, but it was in contact with the body.Escort GTR -- 11.87 @ 117.6 mph -- 320 HP / 325 Ft. Lbs. @ 23 PSI
You da man jon! I say up and foward 1 inch! The car has been lowered at least that much... and the Celica GT-Four has exactly 1 inch longer of a wheel base than this generation escort (when you decide to go AWD you can re-use the complete celica driveshaft with no mods... and you can make me a copy of your upper trans mount right after you make yours)
all of it looks awesome
though i do cry alittle with i see people heat and bend unibodiessuch thin guage with become brittle after that much heat.
too each their own i guess."Discontent is the first necessity of progress."
idk that was his suggestion. we could just as easily notch it and weld in new material. is that what you'd suggest? it clears now but barely, so the whole thing is coming out again tomorrow for either more heat and pounding, or notching...Escort GTR -- 11.87 @ 117.6 mph -- 320 HP / 325 Ft. Lbs. @ 23 PSI
if it was me i would notch it and box it, either way buy the rust protectant with the long straw and spray the inside of that rails as either will compromise its rusty protection."Discontent is the first necessity of progress."
WICKED
I'll be following behind you with a bolt in FE3 next week.
Im subscribed jon, so i'll be following your progress---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
To add to my previous post, bending it cold is less damaging to the metal than heating it in this case but boxing the notch frame is still the way I'd go since you have the tools a a capable welder."Discontent is the first necessity of progress."
wow nice work
sub'n
Originally posted by minnesotapjCost of your fancy German built sports car $35k
price of your fancy sun glasses to match your German built sports car $200 dollars
Getting beat by a second hand 20 year old Japanese 4 door... Priceless!The only bummer about the world ending is that you can't turn to the person next to you and say "WOW! Did you see THAT?!!"
