Have you looked at using the bg carrier bearing support on the toyota bearing and shaft ?
Toyota E153 transmission swap
Originally posted by 801pro View PostHave you looked at using the bg carrier bearing support on the toyota bearing and shaft ?Escort GTR -- 11.87 @ 117.6 mph -- 320 HP / 325 Ft. Lbs. @ 23 PSI
the custom clutch setup arrived in the mail today. everything seems to fit together perfectly, but unfortunately one of the clutch pucks was cracked in shipping. shouldn't take long to have another made up.
pics:
pretty straightforward concept here... 1800 pound high-clamp pressure plate to fit the stock BP flywheel, 225x150mm disc with a toyota splined center hub. the pressure plate isn't "special", i could use any BP pressure plate... the disc is the custom piece.Escort GTR -- 11.87 @ 117.6 mph -- 320 HP / 325 Ft. Lbs. @ 23 PSI
1990 4wd pro - daily beater/monster car/mud buggy( sold)
1993 323(sold)
I'm buying parts i don't need, With money I don't have, To impress people I don't know.
Some people are like slinkies. They're not really good for anything, but they still bring a smile to your face when you push them down a flight of stairs.
i might be selling kits eventually but they would be for FWD. the clutch, adapter plate, upper mount, and some other parts would work for AWD thoughEscort GTR -- 11.87 @ 117.6 mph -- 320 HP / 325 Ft. Lbs. @ 23 PSI
i might just try to get a fwd car eventually they are much easier to work with
________
Expert InsuranceLast edited by Blazin674; 05-02-2011, 08:23 AM.1995 escort wagon gtr/holset
1993 323(sold)
i have a green escort GT that i'm trying to sell, cut you a good deal on it if i can keep the motorEscort GTR -- 11.87 @ 117.6 mph -- 320 HP / 325 Ft. Lbs. @ 23 PSI
1993 323(sold)
more delays...
Apparently the drawing that TurboTim on miataturbo made with his faro arm a few months ago is too far off to use. The machinist making the adapter plate cut a test piece on his CNC based on that pattern, and the crank centerline was off by 0.073". The bolt pattern on the oil pan section of the bellhousing is also slightly different between FWD/AWD and RWD, which i didnt realize.
Anyway, he had his BP pattern scanned on a CMM table locally, and using that new pattern made up a sample adapter... close but no cigar, the crank centerline was still off by 0.010". He is making some final adjustments and should be finished soon. :DEscort GTR -- 11.87 @ 117.6 mph -- 320 HP / 325 Ft. Lbs. @ 23 PSI
sounds expensive lol-Jack
