Can't wait for see this baby running ! mx-3_4evr, yup i was thinking the same thing but i'm sure it's for the safety of the sensor, they are not very reliables
^ in order for a production it would need the outer most closest to the rad support tucked in more. no point in mass producing a manifold we couldnt all use
your o2 sensor is a little too far back? Great welds by the way
Why? it dosen't matter how far it's sitting, it could be at the end of the exhaust it would read perfectly
The reasons, 2 things!
-the car is AWD, have to put it after the tranfert box.
-EGT are pushed to the limit. It's write down of AEM manual that on turbo setup it's better to put sensor 18" away from turbo cause those bosh sensors are pretty fragile. I can tell you I've blown a couple of those, since it's a little far back with heat sink (as per innovate recommendation) I never blown one again.
-1993 Familia GT-R, 3" stainless exaust, 0.100" oversize Supertech pistons, ported and polished head, "hemi" style combustion chamber, Supertech 1mm oversize valves, megasquirt, 880cc low-z, MSD HVC, custom SS ramhorn turbo manifold, GT3076R ar.63, 25psi, 3" SS custom exhaust. Soon to be MS3X, COP and 28psi!
-2008 Mitsubishi Evolution X MR, AEM turbo inlet system, 3" magnaflow exhaust.
-2006 Pimped Grand Caravan 3.8L GT40...I'm kidding, it's stock
I love the manifold, almost enough room to keep the stock radiator in place! im very fond how you tucked the runners close to the engine like that.
Thanks I've work lots to be that squeezed, but if I get the chance to build another one, with all the experience I got with this one, it would clear the rad, but with pusher style fans.
