Shawn's V6 323 worklog
    Sounds goods, what size exhaust you plan on running?
      i currently have a pacesetter exhaust and ill be using the mx3 y-pipe for now. if i need bigger ill go with a cut out
      Originally posted by Turpro View Post
      Sub'n. Thought you were going to keep this under wraps till you were done
      yeah that was the plan but its hard when you have a roomate on the board posting stuff about it and rusty323 over most weekends
        i have a spec stage 3+ disc if you are still looking for a disc. full faced w/ puck material.
          updated the first post with the new stuff i got, only a few parts away and the 323 is already 1/2 apart.
          thinking of adding pheno spacers since i like in 95* 100%humidity
          ville
            hey man cant wait to see the progress when i come down there lol enjoy
              I plan to have it running by the time you get here, dunno how many fancy bits ill have but still drivable enough to hit the track
              Btw if anyone has an obd (93-94 probe/mx6) disty that has a bad ignitor laying around ill buy it if the price is right
                we need pics shawn.
                -Steve
                94' Protege < Worklog<SOLD!
                VF10 powered!
                262 Whp & 257 Wtq
                13.1@107
                '02 Suzuki Bandit 600s
                  picatures fo sho
                    lol everyone wants 1/2 naked pics of the 323
                    Ill post some up when I get home, I finished pullin all the non mechanical connections and radiator today.
                      some general pics, nothing too exciting yet
                      stripping the 323
                      mx3 trans, in need of cleaning
                      filled mounts, and primed valve cover
                      a whole galaxy of uppers downers laughers scream.... i mean my V6 parts shelf
                      knife edged Milli mani, still needs some work, and i still need to get the pheno's and port the heads to the right shape.
                      pic of the car sittiong with the GTX bumper sitting on the back, all of it needs some body work to look sexy
                        Just curious what did you use to fill your motor mounts? ive heard of everything from mighty putty to caulking used.
                        -Steve
                        VF10 powered!
                        262 Whp & 257 Wtq
                        13.1@107
                          i use windowweld super fast urethane. ill have a set of them for the 4 cylinder for salle soon.
                            ah ok. Ill probably just make my own seeing as im trying to do my swap cheap.
                            did you notice a lot of difference when you did that?
                            -Steve
                            VF10 powered!
                            262 Whp & 257 Wtq
                            13.1@107
                              see for yourself:
                              91 323 with intake and exhuast with the Vtec like system working. This was done on a MustangDyno
                                hmm. looks good, and it cant hurt so that will deff be on my list of to-do's.
                                -Steve
                                VF10 powered!
                                262 Whp & 257 Wtq
                                13.1@107
