Originally posted by Mazda_Powered
View Post
Two go in and one comes out (Operation body swap)
Add me onmore pictures of my projects can be found there.
For those who were wondering, the zx2 2.5" TruBendz mandrel kit requires no modifications to the over the rear subframe section. For second gen Escorts its a direct fit. I just finished hanging it and will post some pics later.
I'll take some better pics tomorrow
mmmm tasty-Jack
Soooo I need to redo my vac lines for the wastegate / boost controller and quit using the nipple on the compressor housing. They don't seem to be working together properly with the wastegate sourcing it's signal from the compressor housing and the boost controller getting it's signal from the intake pipe. No big deal though, I'll probably tee off the boost controller and source the wastegate signal from the tee. Wideband is hooked up and reading between 14.7-15.2 at idle. I've yet to check it while cruising and wot.Last edited by jinx; 07-14-2010, 08:00 PM.
^ no different than I was already pointing out.. The controller doesn't like the solenoid and wastegate having their own signal sources.
Started working on fabbing and routing the dump pipe to the ground.
Just an overall shot of the bay.
shiny oil caps are shiny lol-Jack
I talked to mike briefly about when he was off and working vs your schedule. Sounds like monday was the best for him? All depends on what I gotta do beforehand. So find out whats best for you two and I'll go from there.
what trouble are you 2 about to get in?---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
Nothing at all...
