Two go in and one comes out (Operation body swap)
I was talking about the link in this post http://www.wihandyman.com/forum/show...6&postcount=42
I thought maybe you meant stay away from acestainless since they were cheaper lol
Add me onmore pictures of my projects can be found there.
no stainless material in general does not suit this application. you'll thank me later.
Think of my climate & the various weather extremes---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
Mild steel takes the heat better over time but it also rusts like a bitch inside and out. Stainless warps and fractures fairly easy but lasts a lot longer and if welded properly it shouldn't be a problem. Besides I plan on bracing it to the manifold where I cut out more towards the front of it. The only weather extreme here is blistering heat and humidity. It rarely gets near freezing down here. Either way ace is out of the mild steel because customs won't release the shipment and they said it's going to take at least 3 weeks before they can get some in... Going to call around to local places tomorrow and see what I can find.
There is a steel supply house off indiantown and old dixie in jupiter that sells to the public.
I can remember their name at the moment but I'm sure google knows"Discontent is the first necessity of progress."
One in lantana too
if you decide to go stainless i wish you the best of luck. thats how i'll leave it---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
Originally posted by bpt323 View Postif you decide to go stainless i wish you the best of luck. thats how i'll leave it
I forgot to mention that I'm not plumbing the wastegate back into the exhaust. Since I don't have to deal with inspections or emissions I see no need to do it. Anyways I called up a few places today and nobody local had mild in the size I needEveryone needs to quit buying their supplies from china lol... I'll try some other places on monday I guess.
that blows man! how long of a dump pipe are you going to have for the wastegate?-Jack
Originally posted by Mazda_Powered View Postthat blows man! how long of a dump pipe are you going to have for the wastegate?
Started to work on welding up the downpipe but didn't get far because it started to rain and I really don't want to do it inside of the garage. I might also send some of the stuff to jet-hot for coating before installing it.
jethot ftw---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
The downpipe is pretty close to the intercooler pipes just like the vj20's was but I did manage to get a tad bit more room from angling it towards the block. I sure as hell don't wanna use the fiberglass wrap for it... so yeah jet-hot
It's really going to require a crazy pipe for the wastegate in order to squeeze around everything all due to the fact of using the gtx manifold with the adapter. Going to take quite a bit of thought. I'll take some pics here in a few mins.
