you should upgrade the headlight connectors due to the higher wattage output of the bulbs. seem a few melted plugs due to the extra load on the system. otherwise looking good
Project Jay-Spec MX-326GS
Originally posted by progt91 View Postyou should upgrade the headlight connectors due to the higher wattage output of the bulbs. seem a few melted plugs due to the extra load on the system. otherwise looking goodLast edited by IMACHU2; 11-16-2011, 11:33 AM.Dominic Toretto rocks a MaZda and his cell phone number starts in "(323)"
lol sweet deal. pretend i said nothing then haha. carry on kind sir, carry on.91 protege gt. dropzone mx3 springs, mx3 crossmember, ractive front and rear strut braces, rear lower mx3 brace, 4 wheel disc brakes, corksport ss brake and clutch lines,kvr front pads, ractive cai,ram air hood scoop, modified front bumper, shaved ant and rear trunk lock, fubu ant, short shifter, corksport bronzeoil shifter bushings,92 glass sunroof and tail lights, mx3 center console, autometer gauges (volt and oil pressure) cluster needles painted to match, sound system, 17 inch eagle alloy 193 with 205 40 17 rubber. klze is ALIVE BABY!! . http://www.cardomain.com/ride/2394656http://www.toprotege.com/forums/show...hlight=project[url]
curiousity has me thinking about the benifits of plasti-diping the A pillar triims to give them some more durability---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
Originally posted by FE3-323 View Postcuriousity has me thinking about the benifits of plasti-diping the A pillar triims to give them some more durabilityDominic Toretto rocks a MaZda and his cell phone number starts in "(323)"
that's a good idea about the a pillars, would stop them from spider cracking!!-Jack
did you spray plasti-dip them? or actually via a dip can poured on them?
Post up some pictures of them PLEASE!!!---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
I spray plasti dipped the whole car including the A-pillar trims. I am not sure the next time I will be at the garage, but I will snap you a pic. Here is a pic of the mirror, that should give you an idea? (note whole car is also plasti dip spray painted)
Last edited by IMACHU2; 11-16-2011, 07:41 PM.Dominic Toretto rocks a MaZda and his cell phone number starts in "(323)"
Thank you!---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
Got the rest of the murdered-out lights back in.
I repainted the fastner on the rear quarter pop out windows and installed the quarter windows.
Installed the windsheild. It was out of my parts car. first I removed all the old goo.
My first attempt at glass installation. My friend that works at a GM dealershp body shop got me the windsheild frame primer and windshield primer.
Windshield all cleaned up and ready to put in. (this took hours) LOL
The windshield and wipers installed. I broke both of the windshield trims trying to put them back on, they were crazy brittle. I actually managed to get the wiper arms mixed up. Grabbed one that said "P" on it, figured it was the "passanger" side. Turns out if you look closer one says "PL" and one "PR" duh! I was so confused, thought I bought the wrong size wiper blades, actually measured the ones on my driver 323, before I figured it out.
looks good with glass in it!!! i need to pull my windshield out for welding in the rollcage........ not anxious for that one bit.---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
Originally posted by FE3-323 View Postlooks good with glass in it!!! i need to pull my windshield out for welding in the rollcage........ not anxious for that one bit.Dominic Toretto rocks a MaZda and his cell phone number starts in "(323)"
All my Santa's chipped in for the best Birthday-Christmas present ever! :D
I am gathering thoughts and parts to make the sub box & 6x9" boxes quick release and quick disconect for trips to the track.
Wicked~!---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
