thanks! ordered some 4mm silicone hose so I can re-do the vac lines...going to wait for my MBC to come in to check the fittings, I'd imagine they'd be around 1/4 or 6mm same as the wastegate port...but I want to make sure first lol
Mazda_Powered's 91 Protege LX
you nailed it right on the head haha, wiring is the only thing about this car I don't enjoy doing.
Hopefully today I'll have more done so I can bring my fire extinguisher for the first "power hook up and crank attempt" haha, can never be too careful....?
side note, still waiting for most of my parents to come in still...intercooler, bov/flange, mbc, turbo inlet coupler...so as you can tell this is why the piping/cooler is not installed yet haha...friggggg, bov isn't a biggy, but the rest is holdin me back!-Jack
CAR CRANKS OVER! but doesn't start lol, not getting spark. So I added some grounds just in case, and no change. So tomorrow I'm going to make sure the engine harness is getting power, and then if it isn't...fix that issue, and if it's good...then time to diagnose lol.
All fuses are good too, engine fuses and interior fuses. Car cranks over real strong tho-Jack
where are you getting your vac hoses fromhanded down to my old man : 1994 Escort gt
Race car: 1991 EGT BP/bpt
http://www.wihandyman.com/forum/show...racecar-s-life
daily: 2004 mazda 6
http://www.wihandyman.com/forum/show...678-TheSexySix
Welcome to Canada
''It's a shame that today's car forums have "fashionistas" instead of gear heads''
ebay, here's a link http://stores.ebay.ca/Zero-Point-Coo...=p4634.c0.m322 I went with black 4mm, now I have to order 1/4" (6mm) since I got my mbc in today and found some 1/4" barbs for my IC piping.-Jack
if you have power through the harness it should fire up. does your fuel pump work?---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
Haven't checked for power at the harness yet, so that'll tell me lots tomorrow.
As for the fuel pump, yea it works fine maybe my lines are backwards? FPR line goes to the fuel filter, and the end rail to the one beside the fuel filter, correct?
anyways, I'm not too worried about it right now lol, I'm sure it's something easy to find and fix.
I still want to add more grounds to the engine as well, I only have one hooked up to the bracket where the ignition components are mounted. I need at least 5 more lol-Jack
Originally posted by Mazda_Powered View PostHaven't checked for power at the harness yet, so that'll tell me lots tomorrow.
I still want to add more grounds to the engine as well, I only have one hooked up to the bracket where the ignition components are mounted. I need at least 5 more lolhanded down to my old man : 1994 Escort gt
daily: 2004 mazda 6
Welcome to Canada
oh ok haha, well I can fix that today, got those backwards it seems, could have remembered the EGT hose going behind the intake to the filter, guess I was in a hurry lol.
either way there's no spark still lol-Jack
fuel lines are fixed now. So I went to crank it over again, and it cranked fine for about 5 seconds then felt like the starter kept cutting out, so I tried again and it blew the main fuse lol. So I've replaced my main fuse, and I'm going to change the way I have power going to the starter, might be overloading the fuse now that it wants to start...idk lol.-Jack
well after a few more hours of work today, she starts and idles
http://www.youtube.com/watch?v=UjXtOfSSsXI-Jack
god do I ever haha. Today started out real bad too, but it progressively got better as the cars running state would improve haha.
So once I get some $$ I can finish the outlet pipe and get some coolant happening lol-Jack
I'm also thinking about making a lower hard pipe for the radiator, so I can get some more room for the outlet pipe, because idk how the eff you guys fit one in there, there's barely ANY ROOM!-Jack
