you don't need a colder combustion. so having a colder plug isnt' helping per say
Mazda_Powered's 91 Protege LX
I am quite sure he got a good deal! I originally bought it from Jay it's called a Chris Yechum (sp?). Progress rocks, lookin' good dude!1991 Mazda 323 Base (Gretchen)-Build Thread
Sold-1987 Mazda 323 Wagon (Molly)-Build Thread
R.I.P.-1988 Mazda 323 GT (Misty) -Build Thread
Oh Colorado, how beautiful your mountains and awesome your roads!
Originally posted by FE3-323 View Postyou don't need a colder combustion. so having a colder plug isnt' helping per say
Originally posted by Crazypunkerguy View PostI am quite sure he got a good deal! I originally bought it from Jay it's called a Chris Yechum (sp?). Progress rocks, lookin' good dude!
UPDATE: So went to the wrecking yard for some parts today, and ended up coming home with a good haul, I'll be going back tomorrow or sunday hopefully.
- complete glass sunroof assembly
- 97+ escort rad support brackets
- 323 a pillars and screws/brackets
- KLG4 alternator
- KL clutch slave cyl
- mx3 coolant reservoir cap
- 4 wire o2 sensor plugs and pig tails
Gotta get this still
- Protege manual seatbelt conversion
- 90 Supra front/rear seats
- 323 upper spoiler
- Protege LED spoiler
- 99 Protege 1.6 coils
- something else???
Most of this stuff isn't for me either lol, just the sunroof, brackets and V6 stuff.-Jack
Ryan is right to a point, especially when talking about max power. Heat is energy. To get the most power, you'll want to run the hottest plug with the biggest gap you can run without causing catastrophic failure.
For your application, i'd say mimicking the plug that was in the stock BPT would be your best bet, but that's simply an opinion. Sticking with stock BP plugs at relatively low-ish boost and power levels would likely be just fine, but not a risk i would personally take on a street car.
Just my opinion, and no more valid than Ryan's.
That said... the MX6 runs ZFR6F-11s from factory, and i run an "8" heat range in it, gapped to .044" Ideal? Probably not. Safe? Absolutely.
the only reason you should move to a colder plug is when it becomes too hot that it starts pre-ignition.---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
I am running the 1.8 turbo specific spark plugs...I don't know what the problem is guys lol
run NGK iridium's stock heat range & don't re-gap them. if you have ignition issues, check your cap/wires/coil. these motors run well on a .040 gap under 16 psi---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
okie dokie
So I went to purchase a clutch kit from Gripforce's ebay store, and it says I'm blocked from buying and contacting them through ebay...so I emailed both their sales and info to see wtf is up with this, I want to get things rolling with the 626...-Jack
Just dont do it man...
haha jk. Do what you gotta do man.
As I was reading your list I saw Supra seats and thot huh? you can fit those in our cars?? then you later said not everything was for you hmmmm ok now that makes sense.Anyone knows what 9K rpm feels like? I do
93 Mercury Tracer SW
01 Honda S2000 Future Boost
waiting on parts that haven't been mailed is pretty sweet...I guess I can stop waiting by the mail box.-Jack
Originally posted by Mazda_Powered View Postwaiting on parts that haven't been mailed is pretty sweet...I guess I can stop waiting by the mail box.
Originally posted by Mazda_Powered View Postwaiting on parts that haven't been mailed is pretty sweet...I guess I can stop waiting by the mail box.Current:
68 Torino GT Fastback
86 MR2
91 F150
94 Escort Wagon BP swap
99 Escort Wagon BP swap
00 Miata LS
08 Arrow AX8
14 Mazda5
yep exactly lol, still not sure where my oil return gasket is either, no show yet for that. I still want to replace my oil return hose with something better fitting, and oil resistant lol, I think I have the OEM one still, and it's almost rock hard lol.
I should really take some pics because there has been some progress on the car
- glass sunroof assembly swap
- lower window trim installed (missing drivers front)
- BOV flange and recirc port have been welded (never going aluminium again at that cost lol)
- cut about 1/4" off the end of my downpipe's flex section (was binding on oem cat flange) and temp installed it and welded the new flange on to BOLT TO THE STOCK CAT PIPE the flanges I ordered couldn't have been any better lol.
-vac'd the inside of the car after the sunroof swap (headliner was holding in a bunch of **** lol)
Ooook, I'll take some pics tomorrow lol, didn't realize how much I've actually gotten done lol, sweet lol
so ya, I just have work on my outlet pipe, bolt in the downpipe, and somehow tighten the coolant banjo bolts on the turbo, they're sweating a bit might not be bad tho, but I know I can't fit a wrench in there or a socket lol, no room :S-Jack
wow almost 30,000 views on this haha
did some more work on her today, then snapped some pics
found the trans bracket bolt I needed, so she's good to go now
ran some new washer fluid lines
ran fan mounted
showing the room between the IC and the rad
downpipe all welded and painted
new moon roof :D
broke the passengers pillar plastics tho, sucks that it's a US option lol so nothing local will replace it. Figured I'll go manual seat belts next month tho...
OEM weighted shift knob installed
temp rear plate lights mounted, just screwed into the crash guard foam lol (waiting on the proper mounting bracket)
before
during
after
also went to my storage spot and installed the alt on the 626
alt changes on KLs made easy lolLast edited by Mazda_Powered; 05-07-2011, 03:30 PM.-Jack
