So I didn't really make it clear in the first post, but the style that I'm going for is sort of a period-look rally-cross car. I intend to use it at LRP (when I can afford it), at the dragstrip, and ideally auto-x and rally-x. When it's all done, the mod sheet should look something like this:
Engine:
-VJ20 @ 12 psi
-BP26 manifold modified for an external WG
-modified CS downpipe
-2.5" exhaust (gutted cat, resonator, out the side- my old GT's exhaust)
-BPT 330cc injectors
-Bee*R, SARD R2D2, or Sheepdog BOVs
-Audi 1.8T SMIC with a mix of custom and BPT piping
-RX7 or hybrid VAF
-4-wire TPS
-F2T knock sensor
-BP26 ECU
-A/C and P/S delete
Suspension:
-Pierce Motorsports 4-point front tie brace
-Roodwerks motor mount (all others filled with 3M window weld)
-ZX2 struts, MX3 H&R springs
-F/R strut tower braces
-Quickor rear sway bar
-SRD rear tie bar
-EBC Reds, Goodridge or CS lines
-MX3 LCAs/TTLs
Interior:
-Bee*R rev limiter
-SARD 60mm boost gauge
-Tomei turbo timer
-Recaro SPG, Sparco harnesses, custom B-pillar bar (for track days)
-MX3 seats (later style)
-Kartboy STS + shifter, MX3 shift boot
Exterior:
-Impreza Outback hood scoop
-Pontiac GTP hood vents
-RMM grille
-Hella fog lamps
-Hella Supertones
-some sort of period-look wheels (Equip knockoffs? OZ rally bottlecaps?)
-Escort Cosworth upper and lower spoilers
I'm sure there's other stuff I'm forgetting, but that's the basic idea.
Engine:
-VJ20 @ 12 psi
-RX7 or hybrid VAF
-4-wire TPS
-F2T knock sensor
-BP26 ECU
-A/C and P/S delete
Suspension:
-SRD rear tie bar
-MX3 LCAs/TTLs
Interior:
-Bee*R rev limiter
-Tomei turbo timer
Exterior:
-RMM grille
-Hella fog lamps
-Hella Supertones
