92ProtegeLXT KLZEscort GT
    Yes
      Yes. I had a thought of taking the inner mx3 part(the part that slips in to the trans) and put the protege/escort axle shaft on it and see if that works. Not sure if the length or anything works though. I should grab that scort axle from shawn and see
        Went and bought 1995 Kia Sephia 1.8L M/T driver side axle. Cant seem to get it in counted the splines has 28 like the MX3 one
        Whats up with that?
          Sometimes you have to make sure the C-clip gap is facing downward. Not sure if that's the cause
            ok ill try that. IF that doesnt help...any other ideas???
              First compair them side by side and make sure the kia one is shorter.
              "Who Dey"
                Replaced Driver side axle with 1995 kia sephia axle and it did fix the shake in the driver side wheel but the motor and trans still has a rock its rocks from side to side every now and then and not all the time??
                Anybody got any ideas to what could cause the motor and trans to rock side to side moving the whole car?? could it be the passenger side axle??
                  Does this happen during acceleration? If yes, then it's your other axle
                    axle bind would cause that
                      yes its mostly under acceleration does it really bad in second gear
                      had car up on jack stands in first gear when you turned hard left wouldnt really do it then when you turned hard right it would do it pretty bad but when you straightened wheel out it would start going away
                      find out car has a spudder at higher RPMS? thinking bout tieing the VRIS up to see if that fixes it
                        Little update about my brothers escort...this is a drag/street car..Car has been done for awhile and runs great but still awaiting clutch install..it didnt like 4k rpm launch on slicks. Car has been 8.8 @ 80 mph with clutch slipping entire track....with a 2.1 60ft, hopefully with a good clutch and a little less weight we can run 8.5s before the nos...and hopefully 7.8s on gas (75 shot)
                        P.S. K20 civic
