Looking good Stevo, did you get that pacesetter shifter from Scott?
My Full Build Progress FINALLY!
1991 Mazda 323 Base (Gretchen)-Build Thread
Sold-1987 Mazda 323 Wagon (Molly)-Build Thread
R.I.P.-1988 Mazda 323 GT (Misty) -Build Thread
Oh Colorado, how beautiful your mountains and awesome your roads!
Originally posted by Crazypunkerguy View PostLooking good Stevo, did you get that pacesetter shifter from Scott?
Originally posted by wgnths View Postnice progress man. i hope you get this done soon so we all can njoy some vidsMy baby 93' Protege Lx--R.I.P
New Baby 94' Protege Lx Black
91' Miata - SOLD
93' Protege LX new Project (no rust)!
Mods: Protege:
Engine:
Suspension:
Exterior:
Audio:
Originally posted by psiturbo View PostI cant believe the machine shop did not clean the outside of the engine block and put new plugs. I would not have cut the crankshaft, but its not my block.My baby 93' Protege Lx--R.I.P
91' Miata - SOLD
Mods: Protege:
Engine:
Suspension:
Exterior:
Audio:
Need IDEA'S!!! pleasee
Bad news me and BPT323 went to start it yesterday and everything is fine right turns over has spark gets plenty of fuel.
WELL NO TRY TO GO like no pop ****in so we do a piggy back we know his harness works fine so use his main harness and piggy back my fuel pump and still no go. Time to do a compression test to make sure its ok.
on top of that my 460's could be stuck open which i deem impossible due to they just got cleaned and flow tested. The car would try to fire when the Intake cam was almost 180 degrees and when it was corrected all this above happened and we get NOTHING anyone have any ideas of any sort of what could be the issue?
i swear we TRIED everything made sure the rotor in the disty was right, made sure we had spark, made sure timing was correct, made sure fuel was there, made sure the vaf was good. what else can we do the ecu works in bpt323's car so we know thats good! ARG this is soooo fustrating
i can't believe it i just want this dam thing running, over 5 grand into this and now this ****!! GRRRRLast edited by madtownmazda; 09-23-2010, 11:18 AM.My baby 93' Protege Lx--R.I.P
91' Miata - SOLD
Mods: Protege:
Engine:
Suspension:
Exterior:
Audio:
i can only assume that i need more ground it fired like i said with the cam 180 though so it just doesn't make sense to fire that way but not the right way lolMy baby 93' Protege Lx--R.I.P
91' Miata - SOLD
Mods: Protege:
Engine:
Suspension:
Exterior:
Audio:
fuel pump relay, or should I say, "Circuit Opening Relay"? It'll run the pump under 'start' but won't keep going in 'run' unless it's hooked up right. That's one of the three wires I had to connect for my wagon to run, in addition to the coil/igniter wire and the tach.
Just throwing thing out, hoping one will trigger an 'oh yeah!'
--sarge
Double-check that the spark plug wires are in the right order at the disty. Also make sure that the dowel pin in the cam is in the right slot in the cam gear.
--FerdiIf you can't differentiate between brake and break, you should go back to school
Originally posted by ftjandra View PostDouble-check that the spark plug wires are in the right order at the disty. Also make sure that the dowel pin in the cam is in the right slot in the cam gear.
--FerdiMy baby 93' Protege Lx--R.I.P
91' Miata - SOLD
Mods: Protege:
Engine:
Suspension:
Exterior:
Audio:
Originally posted by SgtRauksauff View Postfuel pump relay, or should I say, "Circuit Opening Relay"? It'll run the pump under 'start' but won't keep going in 'run' unless it's hooked up right. That's one of the three wires I had to connect for my wagon to run, in addition to the coil/igniter wire and the tach.
--sargeMy baby 93' Protege Lx--R.I.P
91' Miata - SOLD
Mods: Protege:
Engine:
Suspension:
Exterior:
Audio:
