I dig the scoop, never liked that front lip though... something about the way it comes off the sides of the bumper.
92 mx-3 gs
car's lookin good man, how was the dash swap? pretty straight forward?-Jack
definlitly not straight forward lol. kind of a biotch..lol I used my stock dash harness.. modified a few plugs.. using the 92 emergency flasher but the 95 button still there, so i have 2 buttons.. had to cut the bottom part of the dash off and make custom brackets, and also had to make custom brackets for the sides... also had to do sum custom stuff to make the 92 steering column work but now I got it pretty good, only thing thats odd is the cover piece for the steering column.. but it working good... also used the 92 hvac setup, hacked out the dash part to fit it, hooked it all up and then fitted the dash on after.. but everything works!!
i also removed the airbag, and just siliconed the cover onto the dash... looks great and without the weight!!Last edited by The Pile; 11-25-2010, 01:02 AM.
1992 MX-3 GS - KLZE
1997 Probe GT
Its not a BP05.... Its a BPOS... BIG PIECE OF ****
wow sounds like a bit more than i thought lol, at least you showed it who's boss!
i'm pumped to get my 626 running MTX, i think auto KLs should be illegal lol-Jack
ya its actually pretty easy to do the conversion lol, check out my 626 thread, its a work in progress.
what kind of car? mx6? i'm not a fan of the probes unless its the 96/97 because of the rear end change lol.-Jack
yup 97 probe GTS... heres a couple pics of the car.. Im not entirely sure if its gunna happen or not but im liking the car... super clean with 88k on it..
Doesnt run.. im sure ill have it running in no time. im sure its something stupid. motors been compression tested and its good.. and its a ZE.. I see a bunch of no-no's in the picture of the motor already.. so thats a sign lol.
1992 MX-3 GS - KLZE
1997 Probe GT
oh sweet! then you scored man! KL crank-no starts are usually the ignition coil or the maf i find lol.-Jack
are those PRD wires ?!?!?! whose probe is that/ were did you find that
also any other "close up" pics of that wire tuck?
kinda curious on how you hid some wires like the fuel rails, TPS, vaf, disty
also just make sure its a Legit ZE, cause i no a ZE swap in a 96/97 PGT isnt as direct forward as it is in the obd1 cars from what i herd1996 V6 Escort
1993 escort wagon DE/ZE hyrbid, ported heads, 5 lbs
Well I got a little bit of some updates.. The car has been sitting for a month now due to snow, and im sad.. but its all good.. I dont want this **** gettin rusty..
but I went and picked up a JDM KL-ZE with DE retainers already installed from 4gethonda for the super cheapness.. much appreiciated man!! lol
Im trying to get my hands on a straight neck manifold to go along with this but I might just run the curveneck I got layin around..
1992 MX-3 GS - KLZE
1997 Probe GT
