very nice work... that is some clean looking motors and bay you got there!
and Alex's ultimate EGT build log...
Originally posted by Mazda_Powered View Postawesome job!
Do you have any noid lights to check if the injectors are getting signal? Also the pump may be pushing fuel out the filter but is it making enough pressure? I worked on a chevy full size van that appeared to be pushing a good amount of fuel to the engine but a pressure tester revealed it was not even close to enough pressure to run it, which is why it refused to start.92 Mazda MX3 GS> For sale, $1750 OBO
Aluminum CAS/Distributor caps
BP oil jet eliminators
EV14 fuel rail spacers
More stuff coming soon.......
that's weird, maybe the Kia injectors were low imp? glad she's running though!-Jack
even comparing my GTX setup with my friends 02 Miata with the VVTi there's no comparison lol...well except for the throttle response! That Miata moves pretty good for 138hp at the crank.-Jack
