that won't make a difference, its not orientation dependent. It threads in.
Won't start
It's possible, The fuel pump keeps humming while the key is on, so it's possible my K-code hybrid got bumped, and that's what was causing for it to smell like gas so strong, and not run. Getting fuel/air/spark is one thing, getting the proper ratio is another. I need a wideband :/94 ELXGT, engine and trans located. After pickup, time to start piecing together the stuff I need.
Originally posted by Lord_VaderImpressive.... Most Impressive
Yeah, I'm about to go put my unmolested U-code back in and see if it'll fire up. If that's all it is, then I have to retune my K-code and try again Hopefully it's something stupid-easy, that I'll kick myself in the ass for when I get it figured out.94 ELXGT, engine and trans located. After pickup, time to start piecing together the stuff I need.
Lets just put me down right now. I mean double barrel shotgun style... Twas the VAM, it was about 20 clicks RICH. Oh joy, now I get to pull each plug, clean the mess out of them, tune my disty, and have a ride!94 ELXGT, engine and trans located. After pickup, time to start piecing together the stuff I need.
Nice i was going to suggest hat but by the time i got done reading you had it figured out you might want to still check the tps voltage if it keeps searching for an idle, some one might have played with the idle adjustment screw.1995 escort wagon gtr/holset
1990 4wd pro - daily beater/monster car/mud buggy( sold)
1993 323(sold)
I'm buying parts i don't need, With money I don't have, To impress people I don't know.
Some people are like slinkies. They're not really good for anything, but they still bring a smile to your face when you push them down a flight of stairs.
I had messed with the idle adjustment screw a few times when it was other problems. Should it be turned all the way in? Also, I have the one for my K-code exposed, so I'm not really sure what they should both be set to.
TPS voltage, I know there's a thread on here somewhere, but I would have to dig and dig unless it's stickied. What is optimum for the TPS to be reading?94 ELXGT, engine and trans located. After pickup, time to start piecing together the stuff I need.
Ok well, I went out there with full expectation for it to crank, and well, it didn't fire up... Pulled my plugs out and so far they REEK of gas, so it's still ****ing flooding the car.94 ELXGT, engine and trans located. After pickup, time to start piecing together the stuff I need.
Originally posted by Optimus Primer View PostI had messed with the idle adjustment screw a few times when it was other problems. Should it be turned all the way in? Also, I have the one for my K-code exposed, so I'm not really sure what they should both be set to.
TPS voltage, I know there's a thread on here somewhere, but I would have to dig and dig unless it's stickied. What is optimum for the TPS to be reading?1995 escort wagon gtr/holset
1993 323(sold)
Well, its not even trying anymore, so I'm about to just burn it to the ground and wish for something newer to fall from the skies. With this car it's been one thing after another and I'm really getting sick of it. REALLY SICK OF IT.94 ELXGT, engine and trans located. After pickup, time to start piecing together the stuff I need.
