No dust shields. The bearing has wipe seals and keeping it greased should keep the dirt out.
300zx's ELX work log
Aluminum CAS/Distributor caps
BP oil jet eliminators
EV14 fuel rail spacers
More stuff coming soon.......
Everything fit OK?
What are you planning on doing for the front sway?
I'm sure you've posted it somewhere but not in the last 5 pages.Beater=/= Sleeper
Originally posted by ftjandra View PostEverything fit OK?
--Ferdi
Originally posted by Kitty View PostWhat are you planning on doing for the front sway?
I'm sure you've posted it somewhere but not in the last 5 pages.92 Mazda MX3 GS> For sale, $1750 OBO
i just picked up a RS front swaybar- we should keep in touch about LCA clearance & droplink lengths.---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
What size is that RS bar? It may be a while since I likely won't worry about that drop link till this thing is back on its wheels. Still want to finish the brakes, K-Sport re-valve, engine, wiring harness, standalone, header, and intake manifold before It goes back on its wheels.92 Mazda MX3 GS> For sale, $1750 OBO
Originally posted by 300zxrb26dett View PostI need another set of the tie rod flip bushings since broke both of them trying to remove them from my old tie rods.
Originally posted by ftjandra View PostHey, at least that means that the tapers between the tie rod stud and flip bushings matched perfectly. Those were a pita to make because the tapers had to be super accurate and I don't even remember the exact process I used to make them. When they turned out not to work, I pretty much just expunged all memory of them from my brain (I was sort of sad lol). I have plenty of material though...
--Ferdi92 Mazda MX3 GS> For sale, $1750 OBO
~ 19.5mm .5mm is more than likely the OE powdercoating
I think its a hollow bar- I.E. equivalent to a BG DX protege front swaybar - which is kind of what i was going for- a little less swaybar in the front.---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
I will have to check the GS bar and see what size it was again.92 Mazda MX3 GS> For sale, $1750 OBO
This thread is officially coming to an end.
I am parting out the car.92 Mazda MX3 GS> For sale, $1750 OBO
I just swapped an engine, transmission, ecu, and harness out of a 91 egt into a 95 lx automatic and tried to use the wiring in this thread for the black and white plugs and it won't start. Does anyone know how to wire it for a car that came with auto transmission? Even just the necessary stuff just to make it run, I really need a car to drive.
