92dx gets a 95 EGT. Welcome home!!
    looks good man! weird that the freeze plug was leaking eh? ah well, glad she's getting to your standards lol we all have our own.
      Looks great dood!!! Is ur temp situation better now that u fixed all the leaks?
      1992 MX-3 GS - KLZE
      1997 Probe GT
      Its not a BP05.... Its a BPOS... BIG PIECE OF ****
        I think the sending unit to the gauge is crap.
        the heat is nice and warm in a few miles of driving, like my other cars. Since I replaced the iac, the idle is high like normal on cold start then settles to normal idle, like my other cars. The upper hose gets hot and the t-stat opens like normal, and the fan kicks on for 2 or 3 mins, then shuts off...like it should. lol. Ive bleed all the air out too.
        but my temp gauge never reads higher than the "O" in the "NORMAL" on the temp gauge. On the Escort temp gauge, its barely 1/4 of the gauge. Actually right when the needle on the gauge gets to the O the fan kicks on. I assume its sending unit to the temp gauge, because I didnt replace it. The cooling system works perfectly imo, so Ill probably replace the sending unit...eventually lol.
        DX BP swap/turbo build
          yeah I guess it happens lol. had a small hole in it. Not much corrosion on the inside. you can see how clean the outside of the cylinder is in that one pic.
            Ya my GFs ZX2 has the same issue. Wouldn't heat up, so I replaced the t-stat, but now she's not going past 1/3 of the needle sweep lol when driving, but it'll go 1/2 when idling.... I'm guessing it's probably not the gauge...but maybe the a/c system? I keep feeling the car shake a bit like the rad fan comes on, but it happens quite a bit.
            I know a/c compressors are supposed to run periodically to keep everything working...but maybe it's coming on too soon? your EGT has a/c too, right?
              Guess I should update this some haha. Dropped the oil pan and bolted up a MBSP. New front and rear main seals, cam seals, disty oring and valve cover gasket, Probe Exedy clutch and pp on a 99 miata flywheel. New axles and trans seals. New water pump. 99 miata starter. Did all this a few months ago. I didnt take many pics but I have a few somewhere Ill try to upload.
              On a side note.. bought a vj20, mani and dp, should bee here soon. Getting gtx ecu, vaf and injectors soon. Looking to do just a stock gtx setup and retain the a/c and sleeper status. Red car is still alive and kicking but Im wanting to do the egt up some. Turbo is the only way lol.
                nice! ya next BG will retain it's a/c as well lol
                  Also forgot, new front wheel bearings were done as well. New pads and brake lines on the front. When i had the pan off I didnt drill it for a oil return..dumbass me lol. Rear right caliper has a slow leak from where the ebrake lever arm goes into the casting.. Sucks, and its dripping on the inside of the wheel and eating the clearcoat off. Arrgh.
                  I think Im going to try and use the trigger from the gtx ecu that illuminates the "boost" light on gtx cluster to activate the vics solenoid.
                    That's a great idea for a VICS solution.
                    Current:
                    68 Torino GT Fastback
                    86 MR2
                    91 F150
                    94 Escort Wagon BP swap
                    99 Escort Wagon BP swap
                    00 Miata LS
                    08 Arrow AX8
                    14 Mazda5
                      yep it's the same wire lol, as long as the voltage is enough it'll work fine!
                        Wow, been a loooong time lol. Ill be updating this build soon to its current state, need to get all my pics together. For now here is a peek where Im at.
                        Turbo cleaned up/bolted up, knockbox/sensor wired in, 4 wire tps wired up, minor harness clean up/re-tape, 5th gear swap, gtr intake, custom ps cooler and lines, custom gauges(aem wb, vdo water and boost), act pp/exedy disc, 99 miata fw, turbosmart bpv, filled mouts, Ferdi x-member bushings.... tons more stuff to list out.. Damn near new everything..Its about a week or two away from firing up...Should be a fun.
                        these are just a few pics I pulled from my phone, more to come soon
ID:	1235352Click image for larger version
ID:	1235351Click image for larger version
ID:	1235349Click image for larger version
                          awesome update! keep up the good work man
                            Looks nice and clean. I love me a clean build.
                            1992 Familia GT-X
                            1988 323 GTX
                            2011 F150 Lariat Ecoboost
                            2014 Civic Touring
                              Lookin' good! Keep up the great work!
                              Current:
                              86 MR2
                              91 F150
                              00 Miata LS
                              08 Arrow AX8
                              14 Mazda5
                                Thanks guys, I tried to clean it up nice lol. Its a time vampire, but IMO its the little things that make the biggest difference.
