I ****ing love this car!!! Just went for a shakedown on the local mountain and its just glorious. Paint match is 100% spot on too.
1993 Mazda 323 Astina GT-X
Looks good!!91 GT- Li'l Bee (under construction)
2013 Honda Accord V6 coupe - 14.7 sec. 1/4 mile
New Thread:
Wilyb's 91 Pro GT Rebuild: Li'l B: http://www.clubprotege.com/forum/sho...Rebuild-Li-l-B
Old Threads:
WilyB's 93 GT rebuild worklog : http://www.clubprotege.com/forum/sho...-93-GT-rebuild
My FE3 worklog thread:http://www.clubprotege.com/forum/sho...ighlight=wilyb
Been a bit slow lately due to budgets, but have done some work today.
Fluids checked, oil and coolant topped up.
Both wiper reservoirs filled.
Adjusted the position of the front wipers so they sat a little lower on the windscreen.
Dropped my fuel pressure down from about 38psi to 32psi. My economy has dropped since I installed it and I can smell it overfueling sometimes.
Dropped the rear end down another 15-20mm.
Fixed wiper/indicator combo stick. Dash and tail lights now working.
Glued a rattly bit of plastic back inside the cluster surround.
I've also got my ported vf10 cover in getting a 3" snout welded on. And my stainless 3" intake pipe is having the flange removed and a catch can return 8mm hose barb added to existing plumb back BOV port.
that intake will make heaps of a difference. Did ben help you at all with this??---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
righto! get some pictures of the new intake system up ASAP im anxious to see---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
i really like the VC color choice. its clean---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
I wanted to finish the interior of the boot with the rear strut top covers that have been missing since I bought it. Spent 6 months putting the boot area back together after the previous owner decided to perform 'weight reduction' from the rear seats back. But that's another story.
So I got my coilover damper extended adjusters [mouthful I know] from JustJap. Turns out the shortest ones, 110mm, were much too high and were fouling the rear seatbelt top mount point. So I hacked them down to about 40mm and, after several holes, got them poking up through the covers just right.
i like what you did there. looks clean but not only that its functional!---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
Did my own rust repair today. There were some nasty cancer spots under where the hatch pivots, so I ripped it off and got to work.
Full image galley http://imgur.com/a/Jbnin
Not exactly the best paint match in the world, but it's not a conspicuous place. And I think you'd agree, its better than rust and bare metal. I'm pretty stoked with how it came out actually. I'm used to doing my own mechanical work all the time, but paint and panel stuff I have only just started messing with.
