lois reboot
Long story short. B6 has a new waterpump. but chucked the headgasket
so....... purchased a full gasket kit from "domestic gaskets" ebay seller
ported the B6 SOHC 8v head. and ported his DOHC head at the same time.(a later build)
Took both cylinder heads to the machine shop for a resurface. max shaved the SOHC head for more compression
Plans are to run it NA & see how it responds & then ghetto boost it with a TD04 subaru turbo
just something to play around with meanwhile the DOHC is getting put together.
A few pictures.
Escort gt head. Whale cum to cp.1993 Protege LX-Midnight's shadow SOLD
Back cut valve guides, nice mirror finish on the valve seat, grooves in the quench area, you spent some time on this I see. What are those washers for in your hand?92 Mazda MX3 GS> For sale, $1750 OBO
Aluminum CAS/Distributor caps
BP oil jet eliminators
EV14 fuel rail spacers
More stuff coming soon.......
they're the lower valve spring seats afaik
Looks great Ryan!! I'm excited to see how this turns out lol-Jack
Originally posted by Turpro View PostEscort gt head. Whale cum to cp.
The intake valves are different in this DOHC VS the "standard" they aren't labeled 05 or 06 in the center.
they have a backcut on the chamber side face of the valve. and also one additional 30° back cut on the port side of the valve(past the 45° seat surface)
they appear to be a smidge thinner in the throat area as well.
both good/bad things about this. (the valves aren't SS- so they could burn an edge off easier)
But they will flow a noteable amount more
Originally posted by 300zxrb26dett View PostBack cut valve guides, nice mirror finish on the valve seat, grooves in the quench area, you spent some time on this I see. What are those washers for in your hand?
the washers are the spring seat base as jack said---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
They stick down a ways in my Kia head, so I noticed right away. Funny thing about those washers, I didnt find any in my kia head, but I will look again.92 Mazda MX3 GS> For sale, $1750 OBO
unless your looking for them. you don't notice they are there.
i bought a valve guide removal tool & a 6mm reamer. so if you decide you want to cut the guides down shoot me a pm---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
A few more pictures to throw in.
Finished assembling the engine & transmission & dropped it back in.
has some pep to it for a b6. anxious to see how it responds with a turbo hanging off it.
6lbs shaved off the flywheel!!!!
the ridge behind the ring gear was merely shaved down
Ghetto transmission filling(didn't have any spare hose/funnels)
New HLA's (8)
awesome progress!! question though, how come you left the inspection plate off?-Jack
Originally posted by Mazda_Powered View Postawesome progress!! question though, how come you left the inspection plate off?---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
well- the headgasket did not hold. blew between cylinders 2/3 on the exhaust side.
Not sure if the block is warped at this time or perhaps was to start with...........---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
