Water on the #2 piston, a discolored head bolt. The head doesn't appear to be warped. Does all that discoloration on the cylinder deck indicate head gasket leakage?
Also, that is damage you see at the top of the first pics. Predetonation? Impact damage?![Confused](https://www.clubprotege.com/forum/core/images/smilies/confused.gif)
And yes, there is water in the oil as well. This cylinder has been going south for a while as indicated by low compression readings.
