93 lx
I went to the junkyard and got a new A/C switch (the old one was scratched up), white pull handles for the trunk and fuel cover (to replace the yellow ones), a front emblem, two door switches, and a stock radio.
I replaced the radio and all of the speakers started working and now I have working buttons and tape player.
I also replaced the emblems he painted black with other emblems (I have a ton). I put a metallic Protege/323 emblem on.
I ordered new motor mounts and shifter bushings.ClubProtege
Got an ultra-rare SILVER topped A code vaf. [emoji6] The silver topped A codes have a 12% better flow than the black A codes.
Ring terminals arrived for redoing some grounding, shifter bushings are here, and fuel pump should be here this afternoon [emoji33]
Accidentally bought 460cc injectors off eBay by making an offer that was accepted [emoji13]
Not much left to buy
Sent from my One M8 using TapatalkClubProtege
LOL at silver top.... who made that---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
fancy fancy---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
McMaster Carr "shifter bushings" installed and they are amazing. I was missing one bushing, so this made a world of difference.
Got some grounding wires added.
Went ahead and installed my 255lph fuel pump too.
I need to hurry up and finish buying everything!
you are rocking out!!!! keep up the work!---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
Originally posted by skreenhumper1 View PostHells ya looks good just with that little bit of miles do every thing professional I got lucky with mine had 200xxx miles one it and it was luckily taken care of and the rear protege 323 emblem is awesome trust me!
Sent from my SAMSUNG-SM-G870A using Tapatalk
It actually has a cheap paint job over the original tropical emerald metallic that is MORE tropical emerald metallic than before. It's nasty.... but I think I'll get the last laugh [emoji4]
So I believe my only big parts left are:
Intercooler and piping
Bov
Turbo timer
Wideband o2
Gauges
For the intercooler piping, I'm trying to figure out where and what I need to tap off of it. I'm planning on a silicone coupler for the BOV. Where do I want to tie in the wastegate actuator? Anything else to tap off for?
Sent from my One M8 using TapatalkLast edited by Dixie94Pro; 07-24-2015, 11:20 AM.ClubProtege
anxious to see what you do here---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
