Car is 1991 Protege LX with BPT swap with 100K on it. Rebuilt by me a few years ago after over heating it and ruining the GTX head. Replaced intake and head with BP j/y finds. Bored block, 10:1 pistons, vj20 turbo freshly rebuilt. ++
If somebody were to come at me with an e153, or a Kia intake, I might be interested. I don't have a lot of money but these are problems I need fixed. Information is golden. My current solutions are working but they're imperfect. Am also thinking of new clutch. My spec 2+ is getting pretty thin at this point.
Other problem to fix are oil burning from improper break in, rebuilt turbo getting noisy possibly causing my power loss, shifting front suspension causing my alignment to always be off, stripped drivers side window.
The engine hoist is in the process of getting fixed. I can't replace it unless I make some kind of effort to fix the leg I bent using it to pull plugs out of the ground from fence posts that had rotted off. Am still cleaning the garage to make it ready. I plan to source the gasket set from NAPA so if they give me the wrong one, I can simply take it back. A set for a big nose crank will have the wrong pan gasket. I'm thinking of doing the intake cut mod. I ruined one intake being impatient and now believe I could do a proper job. I also have a better tool to do the work with so no more 4" grinder.
Needed still.
4 cans parts cleaner
break in oil and filter
My old magnetic oil plug was stolen by crows during an oil change last summer and needs replacing
rings for .020 over
gasket set
Permatex
Inspect head carefully and make sure I got seals in properly.
hone cylinders and replace rings
maybe remove high flow cat since car is past DEQ
fix leaking radiator, (pin hole leak)
I very much want to be three quarters done with this by the end of vaca two weeks from now. We'll see how that works out.
As usual, I'll be updating and editing the thread as I go. I'm going to attempt to not make any of the same mistakes I've made in the past. I must be running out of things I can do wrong by now.
Needed still.
rings for .020 over
gasket set
Permatex
