Ok here is the list Jesse gave me:
90-93 Protege pistons = 8.8:1
94 Protege pistons = 9.0:1
94-97 Miata Pistons = 9.0:1
99-00 Miata pistons = 9.5:1
01+ Miata pistons = 10.0:1
I'd be interested in the 99-00 pistons because of the little bit of an increase in compression ratio and possibility of finding aftermarket forged ones or something. My question: do these fit directly into the Protege?
jesus is wrong protege B8 is 8.9:1 and protege BP is 9.0:1 this is for 90-94
I decided against it b/c of the ends not being bead rolled.
For the time I plan to use the OEM GTX IC, and will probably upgrade to a DSM SMIC, or Probe/MX6 SMIC. I dont want to go on both sides b/c of having to go around the AC compressor issue.
Time shall tell as I am sure I will want more boost than the vj20 can offer.
I have Miata 2002 pistons in my car. they read a 230 psi piston compression ratio. I installed cam gears to "compensate" for the piston clearance. I do not complain about the swap but I know the cylinder head needs performance camhshafts. The factory cams do no give justice to the Miata Pistons. I have had a lot of fun with the new setup and smokin many Mustangs and GSR;s... Lately with Power steering, srtock cran shaft pulley and air conditioner the car does a personal best of 15.80 @ 93 mph with two 10" sealed box and stereo system and 2 car seats.
And this was with almost bald Ziex 512, cant wait to install the Nitto drags 555R 14" with Del Sol rims in the front and see how it does 60 mph.
...the car does a personal best of 15.80 @ 93 mph with two 10" sealed box and stereo system and 2 car seats.
LOL. You smoke stangs and GSR with a high 15 sec car. no offense but come on d00d.... Look up Limpgtx's setup if you want to see a mazda that can smoke GSR's and stangs.
they either were not trying to race you and you punched it off the line or they missed every other gear when shifting.
I've beat every Mustang I've raced. All two of them. Once on the street, and once at the strip. It's EXTREMELY easy for a 5.0 to be out of tune and running like ****. Combine that with a crappy driver who doesn't know how to launch, and a win is easy....
ok so if i were to build a turbo engine and i wanted to use a Modified BP head, 15 Psi from turbo. what kind of pistons should a use for best reliability but doesn't waste Hp? what size intercoller and piping should also be used ?
