I'm having some trouble with my transmission. When starting off in 1st it tends to give a slow drag when taking off. So, I'd give it a bit more gas before releasing the clutch(to 3000 RPMs). Then as I release the clutch, the RPMs will tend to drop without me depressing the gas pedal.
But, sometimes, it will give that fast accel like it should. But, when I do get that fast accel and I have to slow down or stop, that's when the problem may arise again (90% of the time). And, after receiving that fast accel, if you press down on the accel pedal you won't see the RPMs raise and you won't hear the engine rev.
I do notice, before starting off, that if my RPMs are around 500 that my car will give that sluggish/slow take off. But, if my RPMs read 1000-1500 then my car will give that fast accel.
(Before this problem came up, and during, it's rough to put it in gear. It doesn't just slip right in, you actually have to pull it in there. And, when putting it in reverse, you feel a slight jolt and hear the tranny knock as you put it in gear. Sometimes, it won't even go into reverse. At times, it didn't want to go into first.)
Can anyone give me a better idea as to what my problem is?
I figured that maybe someone went through the same or similar problem and could kind of let me know of an estimate as to how much it might cost to fix this problem.
Thanks for your times.
