OK as some of u know , i am purchasing a used 99 miata motor. And Ive read all of you alls discussions about the camshafts-piston-duration-lift. And it was very very informative, but ive got a few questions.
1. When installing the 99 miata camshafts/solid lifters is there anything extra involved. I was reading the interchangeability faq, and i read this
"The only hard part is setting the lash. Using the 99+ cams in a M1 head requires using shims that are .020-.030" thicker since the cam basecircle and valve stem are slightly different. You will have to install the cams, measure the cold lash, and then order the required size shims. From the factory they come in 2.75mm - 3.75mm thickness about every .002 - .003" (~.05-.06mm) "
This only worried me because i have no idea what the "cold lash" "shims" are, i have an idea but im not 100% clear.. ive done alot of engine work but ive never messed with internals before. i was thinkin that the camshafts-lifters will go right into my 93 bp, and is just a matter of swappin the parts out. Anyone care to elaborate?
2. When all this is done what will this increase? top end? Low end? Compression slightly? Horsepower? TQ? And what will help this swap even more?
3. Am i wasting my time installing these camshafts without installing the pistons also? Has this been done before?
4. Would completely swapping out the head internals be a safe route, or a waste of time?
My biggest fear is a bent/broken valve and my only car being out of commission. i have read and read all the threads about this and ivee asked alot of CP people via AIM about this and alot of them are clueless as well.
