neutral switch ?
    neutral switch ?
    I just finished today my 5 speed swap, but i need to know
    how to start my car, what wires do i have to jump or run
    thanks.
    1st sohc auto
    2nd sohc turbo auto
    3rd sohc turbo 5 speed
    4th dohc swap turbo
    5th KLDE
    6th 1994 323
    Haha.... What????
      Put the clutch in.
        lmao that's not what im talking about, what im talking about is how do i connect
        the neutral switch to the manual tranny so the car can start
        but thank you anyways i found the way.
        1st sohc auto
        2nd sohc turbo auto
        4th dohc swap turbo
        5th KLDE
        6th 1994 323
          ok .... you've got things messed up.... the nuetral switch does nothing but..... slightly raise the RPMS to smooth out shifts.... kinda like an automatic rev match.
          nuetral switch and back up light switch...
          Tear apart a tranny or 2 you'll see.
          the nuetral switch may or may not need to be installed .... i don't remember. as for the swap.
            You have to jump the big black/yellow and the big black/red wires on a WHITE connector which is/was at the top of the trans. It's a 3 wire connector, the other wire is a small red/blue one.
            Past: 1994 White Protege DX ~DEAD~
            Current: 05' Onyx Black Mazda 6 'S' ~Bone Stock~
            Originally posted by TheMAN
            you MUST keep in mind the 2nd gen is the bastard child of the proteges...
              The answer is a few posts below this one titled" Auto to 5-spd conversion"...
              Anyway-- Here is the thing you are looking for:
              This harness is located on the drivers side of the car, sorta under the VAF.
              And for those who posted above and laughed or posted stupid responses-- this has to be looped or the car will not start.
              ___________________________
              ~Perry B.
              MX-3 Owners Club of Atlanta
              http://www.mx3-atlanta.com/moca
                I think most of us didn't understand the question the first time around.
                  precisely
                    Unless you have done the Auto->Manual conversion.. then you would not know.
                    ~Perry B.
                      Did you get my private message ? You should have the infos you need.
                        I understood but did not know the answer.
                        2006 Mazda 3 hatchback manual
                          About the transmission swap
                          Hey man what up Im just on the straight away of finishing the swap . I fixed the nuetral swith problem and starts perfect. My Problem is that the clutch pin doesn't make it to the to the cylinder so Im not able shift into gears. My transmission is from the kia Sephia . Any suggestions?
                            weld extra onto the clutch pin to make up for the clearance... then have it machined properly.
                              i did the swap and my reverse light sensor and neutral switch sensor are both broken and not there and i have no problems
                              91 323 GTX @ 16psi, 5 speed || December 07 R.O.T.M.
                              More Information
