Why not deactivate the VICS and remove it's components, making the intake manifold all open all the time? Or why not trick it into opening whenever the TB is at WOT?
The reason I ask this, is back when I used to tune Ford Focii (plural of Focus), the big "trick" for the SPI motor (split-port-injection) was to have the VICS (Ford had a different name for it) to open at WOT, or at a lower RPM, or just be open all the time. You lost a small amount of low-end, way at the bottom, but mid- and high-range power was increased.
Next question would be, how exactly does the VICS on these motors work? I'm assuming it's electrically activated, in which case it would be easy to "trick" into opening at lower RPM, or at WOT.
Any help?
Any help?
