Originally posted by thunderb0lt
I am with FESTIVAS RULE on this one.
Reground cams will reduce lifter noise PROVIDED they are milder than the stock cams.
The lifters tick when they are starved for oil. They starve for oil when they are clogged OR when the ramp rate is too high... ie... when using wild cams.
The ramp rate has nothing to do on the aggressiveness of the cam lobe profile. An aggressive cam by definition is a cam with duration that starts making the idle lopy or to the point of not idling. Cams with 264+ degrees at 0.006"lift can be considered as aggressive for the BP engine.
