BP motor in SOHC MX3 update
    Took you long enough to reply.........
    2006 Mazda 3 hatchback manual
      what is so hard about getting the right ecu for the bp engine. instead of spending more money on an AFC, just run the 2 extra wires to the VICS and the Disty and your done.
      You can get the ecu from someone with a spare for cheap. Why not just buy the right ecu and wire it up.. It will take you no longer than a half hour to do ..
      dbest1a AT yahoo DOT com
        I'm running my gtx engine on my bp ecu and the plug for the vics is not plug and i never have a check engine light.
        http://www.cardomain.com/id/protila
        Transmission mechanic
          that would be an anomoly. but if you have a wire in the wrong spot your car could be sending voltage to VICS pin.
          When you turn your car on... does it return the favor?
          Originally posted by goldstar
          Yes, still have it. It was my attempt to immortalize you in verse.
          A Protege driver named Brock
          So his engine he goosed
          With much too much boost,
            Originally posted by TheMAN
            93-94 MX3s have the SOHC 1.6l like the 323s did.. the 95+ ones have the 1.6l DOHC like the 90-93 Miatas did.. all the 1.8l MX-3s are K8-DE V6s
            the 92-93 mx-3's came with the sohc
            the 94+ came with the dohc
            2006 VR Mazdaspeed6
            2004 VR MazdaSpeed Mx5
              ya...i was gonna reply but you already corrected em
              93' Noble Green MX-ZE (sold )
