USDM the intake is BP05 & the exhaust is BP06, we use 2 BP06 cams can't say if they are better or worse then what you have
exhintake questions
the BP22 is suppose to be more aggressive then a BP05 inlet cam if i remember right.---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
well i tried again
FAILED ..FAILLLLED
stilll had NO pull at all
so i put the BP22 cam back in.....i now have Torque in the low and mid, top end is the same as when the exhINT cam in there
i just dont under stand, i should have worked.
this is a quick vid i tried
didnt launch it as you can tell, but im more interested in the 2nd to 3rd gear area? is this close to what you US n/a guys do?
seems like it pulls nice to me. it's been a while since i've driven a modded BP tho
JACK.-Jack
very hard to tell unless you did a dyno comparison---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
Originally posted by Justbp-me View PostCan we condense this and do a write up?1993 Protege LX-Midnight's shadow SOLD
this lack of midrange he describes makes me not want to try thisEscort GTR -- 11.87 @ 117.6 mph -- 320 HP / 325 Ft. Lbs. @ 23 PSI
well all i can say is;
when using the ExhINT mod with the follow engine doesnt work
9.8:1 BP22 pistons
BHA 12kg crank
GTR flywheel
BHA 1st gen head, with casting lines removed
BHA new 2nd gen valves,springs, retainers etc
1st gen BP06 exhaust cam
BP22 BP05 exhaust cam as Inlet cam <---didnt work
BP 2nd gen BP06 exhaust cam as inlet cam <--also didnt work
BG Inlet manifold with the Cut VICS options, all cast lines removed, polished
OEM cast exhaust manifold flange enlarged to 2" and with mazdaspeed lantis 2" exhaust system
Same results with ether OEM computer or Link G3 computer
sorry guys didnt work for me,
i have bp-ze infini and i used a bp22 for intake duties and the bp06 for exhaust and it seems to be pretty good is very driveable and seems to have a bit at low end
also i used bp06 and bp06 and it was very good at 100km just cruised awesome also had good torqueLast edited by LRCboi; 04-18-2008, 03:02 PM.
for the exintake mod you use the standard bp06 exhaust cam on exhaust and a bp06 exhaust cam modified at the disty end to fit in the cam cover and use that on the intake side it has a better down low i found the bp22 to be better and is more free revving and just cruising at 60 or 70km it wanted to really go
i have a bp2 engine
the bp22 is a higher compression and more aggressive cammed engine im not 100% sure what it is from ... i got my bp22 cam from a tx3i engine over here in NZ the exhaust cam that came with that cam was a bp05
my pic in finding both of those cams
the bp06 is from a BP2 engine in protege and mx3 i think (SOMEBODY CORRECT ME IF IM WRONG) its stamped behind the exhaust manifold so get a bp06 and modify it for your intake side
now BP22 not 100% sure what you have over there i heard they were rare over there so it could be in anything look for more high performance models when you find one you can just fit it in your intake and your away
mine took a wee while to adjust so reset ecu and was fine
