Another question, there isn't a set tuning, so you totally need to dyno tune these? Or is there an estimated cam setting that you can adjust it to?
exhintake questions
I'm thinking about doing this without the adjustable cam gear since it would be free. So supposedly the timing would be 1/2 tooth off... Does anyone know how that would affect the low/midrange power? I also was given the idea of taking the tab thing off the gear then rotating it slightly, and tack welding it back on, effectively shifting the gear by 1/2 tooth. Any ideas on this?
Originally posted by 1967cutlass View PostI'm thinking about doing this without the adjustable cam gear since it would be free. So supposedly the timing would be 1/2 tooth off... Does anyone know how that would affect the low/midrange power? I also was given the idea of taking the tab thing off the gear then rotating it slightly, and tack welding it back on, effectively shifting the gear by 1/2 tooth. Any ideas on this?
assuming theres enough room to where the holes dont overlap
id just fork out the money for 1 adjustable cam gearMy Car Domain
My VB Garage
1994 Protege LX
Cold Air Intake
Cat Back Exhaust
5 Speed Tranny Conversion.....Coming This Summer
Originally posted by OUfb2005 View Postassuming theres enough room to where the holes dont overlap
All you'd need to do is bore the factory hole a little, adjust the cam gear in that direction, then fill the other side in with weld. Then install it 180' inverted and move it 3 teeth and the timing will be dead on. For free.
Originally posted by 1967cutlass View PostNo. bad. bad idea.
All you'd need to do is bore the factory hole a little, adjust the cam gear in that direction, then fill the other side in with weld. Then install it 180' inverted and move it 3 teeth and the timing will be dead on. For free.**SOLD** 93 EGT with more suspension mods then your average riced out civic's # of decals + useless "bling/style/culture" mods! **SOLD**
Originally posted by 1967cutlass View PostWell I haven't ACTUALLY tried (I will this weekend) but I'll post a how-to assuming this works.**SOLD** 93 EGT with more suspension mods then your average riced out civic's # of decals + useless "bling/style/culture" mods! **SOLD**
I thought about something. Maybe somebody could answer this. I'm only going to be running the stock bp cams when I boost it. Ryan runs the gtx exintake cam. What if I just used the bp exintake cam with a boosted setup? Would it hurt to do? Would there be a decent amount of a power gain? I'm figuring it won't be as good as a gtx exintake cam but might be a little less hp than it.1993 Protege LX-Midnight's shadow SOLD
if you look at the cam specs they are pretty damn close, aside from the timing. so with adjustable gears it should work alright.
Yea I would only do this mod with adjustable gears.1993 Protege LX-Midnight's shadow SOLD
Originally posted by ftjandra View PostInstead or removing the dowel pin off the cam, I would just drill a new hole in the gear in the right spot.
--Ferdi
