How many of you drained the coolant from the block when you replaced you radiator? It seems like a bitch to get a socket to that drain bolt on the block and it seems like the coolant would make a mess coming out from the side of the block.
Should there be any sealant around the thermostat housing? I am having a damn hard time getting the housing off and it looks like somebody uses a white sealant all around the edge. The only thing I saw in the FSM is a bolt and the gasket, nothing about using sealant.
