Im doing the DOHC swap and theres this thing at the intake looks like a throttle position sensor, the SOHC has 3 wires the DOHC has 4, I cut the harness for the DOHC and used it where does the 4th wire go?
DOHC swap question
why exactly did you cut it????..... that doesn't make much sense---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
uhhh on harness was a 3 pin, the plug was a 4 pin? how the **** would you solve the problem???When you turn your car on... does it return the favor?
A Protege driver named Brock
So his engine he goosed
With much too much boost,
Couple questions. Is the motor from a manual or auto? Is the car it's going into going to be using a manual or auto computer? Is the car going to be manual or automatic? Because autos have 4 wire TPS's and manuals 3 wire. If i got this right the harness that came with the DOHC is from an auto becuase of the 4 wire TPS, wich means you are propably using an automatic computer. So I would put the harness back together and swap the whole harness. Or if the car is getting a manual transmission the 4th wire may not matter but the computer might still be looking for it and throw a code because it's an automatic computer. I don't for sure if it will throw a code.
Hope this makes sense.Last edited by bam; 11-05-2003, 02:28 AM.
he will be using a manual computer so i think that wire can just be taped off.When you turn your car on... does it return the favor?
i know when he said he cut the wires it sounded stupid right? your wrong. thats how i did my swap. Bro! u will need a schematic diagram/ wiring diag. i cant explain u everything here its has been 8 months when i did my swap.
the only thing i remember is tha there is 2 wires u need one for the VICS and the one for the ignition or some **** like that i gotta look it up then i'll let u know 2morrow late!
Re: DOHC swap question
First of all the 3 pin TPS is for MTX(manual tranny) and the 4 pin TPS is for ATX(auto tranny). Install your SOHC throttle body, and install a new TB gasket (about $4Cdn).92 323 with BP DOHC
ported/polished head, regrinded cams, JUN adjustable cam gears, ported AFM, ported/knife edged intake manifold.
N/A project dropped.
