I was just wondering if there was another way to tell if you have a dohc ecu other then reving the car to 7500 rpm?
Dx to Lx but with a twist
well loock at your ECU and read off the code, it wil go BP##
FWIW my dohc ecu is coded BP10When you turn your car on... does it return the favor?
A Protege driver named Brock
So his engine he goosed
With much too much boost,
oh look under your hood. if there is a factory DOHC engine then there is probably a factory DOHC ECU. if you have an sohc ecu on a dohc engine you would be having issues with your idle, and pickup.When you turn your car on... does it return the favor?
engine or ecu?When you turn your car on... does it return the favor?
