I just put my car on the dyno got 92 gtx swap in it but when i floor t it feels like it leans out around 4500 or 5000 but when i dont floor it and g rev up slowly it goes all the way up 2 6500 easy with no problem what could it be? also my boost is at 9 psi and got rx fuel pump and stock vaf timing is around 8??
Rev kill at 4500 if floord
What'd the dyno show your AF doing?'90 AWD Protege, full GTR drivetrain swap, ~320 whp daily driver, RIP, and
the wiring is in the VAF i believe, you'll have to search around. I'd post in the forced induction section if i were you. You're definately hitting boost cut. Have you tried adjusting your VAF?
JACK.-Jack
It sure sounds like boost cut (which is the vaf cutting the fuel because of the rush of air). But if you are using the stock vaf I dont see why it would cut. Look up rx7 vaf and there is some instruction on how t adjust it.Mx3 RS,BP-turbo
http://www.cardomain.com/ride/2628805
if you floor it in 4th and 5th without a ported wastegate and have a free flowing intake and exhaust you will hit boost cut
my boost is 11psi all day no controller but when im just cruising in 4th and try to floor it i hit boost cut
the car will feel like it bucks and you have no power right?
