Can someone please tell me the firing order for 93 SOHC, I don't have my book and I need to get to work!!!!
HELP I need the firing order!!!
4123cw starting top leftWhen you turn your car on... does it return the favor?
A Protege driver named Brock
So his engine he goosed
With much too much boost,
ok it goes Far left(pside) piston(1) , 2, 4, 3
i was backwards. and on crack.
take a look at your car it is 1243 going c-clockwise starting from the top left.When you turn your car on... does it return the favor?
so do i and i have the car out front. that is the firing order of my cylinders.When you turn your car on... does it return the favor?
read that backwards.
1342 => 2431 rotated is 1243
we are saying the same thing. it all depends on wich direction you rotate around the disty cap.When you turn your car on... does it return the favor?
positive rotation by convention is CCW,When you turn your car on... does it return the favor?
