What temperature thermostat does the pro come with stock? Anyone run a cooler one? like a 180 degree? If so what is the part number, i couldnt find one at my parts store.
Colder thermostat?
The single stage thermostat opens at 94-98 degrees celsius, IIRC.
If you can, try finding the two stage thermo. If you go to the parts store, tell him it's for a '90 323 GTX 4WD. If he asks which engine, just tell him to pull the part for both so you can look at it. Though, it should be for both the SOHC and DOHC. It'll definitely be under the Turbo model.
The two stage thermostat regulates the coolant temprature hella better.
If you still need a cooler one, it'll be up to you to find one that fits.
Hope this helps.Last edited by zenilder; 09-03-2003, 05:06 PM.Bryan
MOCC MEMBER
-"Mean people rule."
Originally posted by midnightblue97
Thought the oil pump was run off the timing belt??
Originally posted by zenilderThe single stage thermostat opens at 94-98 degrees celsius, IIRC.
Hope this helps.2006 Mazda 3 hatchback manual
Actually, the year of GTX I read the info about is a '92. I'm assuming that the two-stage should be in all the GTX from '90. I really can't say for the 89 or older.
As for another two-stage from another car that -would fit-, I'd have to spend a day at Autozone.
EDIT: should also be in the GTR 90-92.Bryan
MOCC MEMBER
Originally posted by zenilderActually, the year of GTX I read the info about is a '92. I'm assuming that the two-stage should be in all the GTX from '90. I really can't say for the 89 or older.
Autozone carries parts for the gtr? in the states?
A US store having parts for cars only overseas? errrrr....My ClubProtege.com Feedback Thread
MOSI Race Dynamics - Aftermarket Parts Sales & Services MOSI Race Dynamics Feedback Thread
