Porting??
    huh?
    top where? it's 180 degrees....so the "top" is both the small AND big radius, depending on where you're looking.
    -93 MR2, 129 ES
    ClubProtege.com Tech Articles
    Originally posted by WTF
      Originally posted by JesseSays
      huh?
      The top (roof) is the surface which has the small radius.
      When I ported/polished my intake manifold I polished all the runner surface areas, since the surface was 40 grit. I also knife edged some areas that would of created turbulance at high engine speeds.
      92 323 with BP DOHC
      ported/polished head, regrinded cams, JUN adjustable cam gears, ported AFM, ported/knife edged intake manifold.
      N/A project dropped.
