anyone anyone?
best sparkplugs for a protege
NGK coppersWhen you turn your car on... does it return the favor?
Originally posted by goldstarYes, still have it. It was my attempt to immortalize you in verse.
A Protege driver named Brock
So his engine he goosed
With much too much boost,
Originally posted by Ambassador
do I need higher octane for those?-------------------------
'91 LX
'03 Mazdaspeed Protege #235
Originally posted by pigeonwell if you're a fan of inaccuracy and uncertainty.... then by all means, go set your timing by feel and sound
while you're out there, you might as well adjust your air/fuel ratio by smell... and your tire pressure by ride height
I tried platinums against a bunch of posts that stated otherwise. I wasn't really impressed.
Coppers are cheaper.
Save your money.Ryan The middle child is always ignored
Originally posted by jnorion
OK, let me restate my question slightly. My car has not quite 10k miles on it. I have a friend who insists that if I buy a set of spark plugs for 16ish dollars I will be able to feel a slight hp difference and my car will run better than if I just keep the stock ones. Is this true?
If your car only has 10k on it, you don't need new plugs really. Stick to the coppers.Ryan The middle child is always ignored
That's what I figured but I thought it was worth asking.
Or reading.Ryan The middle child is always ignored
Need to by new Sparkplugs. Engine BP DOHC N/A, 2,5" full catback, F2/FC VAF, custom CAI, Walbro fuelpump. Any sugestions? Fuel what I use is Euro E98. Thanks!My BG Familia FE3 project full spec and plans.
www.mazdasgarage.com/forum/ New mazda tuning forum
1/4 mile drag with BP DOHC engine:
Reaction: 0,5771 (not so bad)
60 ft: 2,472 (good for conditions what was)
ET: 16,2411 (but was heavy wind from front and custom intake was just compleated in nigt and setings was worst than bad )
