Officially the oldest thread ever bumped.
best sparkplugs for a protege
BKR6E-11 is what i used to run on my non turbo BP'sEscort GTR -- 11.87 @ 117.6 mph -- 320 HP / 325 Ft. Lbs. @ 23 PSI
Can anybody say what is different between BKR5E and BKR6E-11?My BG Familia FE3 project full spec and plans.
www.mazdasgarage.com/forum/ New mazda tuning forum
1/4 mile drag with BP DOHC engine:
Reaction: 0,5771 (not so bad)
60 ft: 2,472 (good for conditions what was)
ET: 16,2411 (but was heavy wind from front and custom intake was just compleated in nigt and setings was worst than bad )
Originally posted by ivan15 View PostI am currently using autolite copper spark plugs. I bought them from car quest, but you can also get the same plugs cheaper at WalMart.
Save the Autolites for your domestic small block boat anchor.92 Mazda MX3 GS> For sale, $1750 OBO
Aluminum CAS/Distributor caps
BP oil jet eliminators
EV14 fuel rail spacers
More stuff coming soon.......
Originally posted by Mazdagirl View PostCan anybody say what is different between BKR5E and BKR6E-11?
In Denso plugs, 16 is equivalent to NGK 5, and 20, one heat range colder, is equivalent to NGK 6.
Originally posted by 300zxrb26dett View PostNever use anything but NGK or Denso in japanese engines, which are OE brand plugs.
Happy Motoring!Last edited by goldstar; 04-15-2010, 06:30 AM.02 DX Millenium Red - The Penultimate Driving Machine
So for my original pistons engine can I use BKR6E or I need use BKR6E-11? different between they are?My BG Familia FE3 project full spec and plans.
honestly I don't know, I've never seen a non 11 plug...
oh wait
check this out I just found an awesome guide.
From the guide, I think that if you get the ngk bkr6e, it just means they're ungapped.
The number after the model represents the gap size.
nick
http://www.ngksparkplugs.com/docs/te...tnumberkey.pdfPosted By: Wheresthericego
The BP crank is made out of invincible.
BKR5E: V-Power, nickel alloy type with an .9 mm (.035") gap. Not listed for use in any Mazda. Other than the gap, same dimensions as BKR5E-11.
BKR6E: V-Power, nickel alloy type with an .8 mm (.032") gap. Not listed for use in any Mazda. Other than the gap, same dimensions as BKR6E-11.
Mazdagirl, use the correct -11 plugs with a 1.1 mm gap which are meant for the Mazda Proteges and clones. Neither NGK nor Denso plugs are meant to be re-gapped; that's why they're made in a variety of electrode spacings.
Both the BKR5E-11 and the BKR6E-11 plugs also have equivalent precious metal electrode types (platinum and iridium/platinum) if you're looking for a longer-lasting, higher-performing spark plug.
Happy Motoring!Last edited by goldstar; 04-15-2010, 07:25 AM.02 DX Millenium Red - The Penultimate Driving Machine
Now choised colder BKR6E-11, but need new wires to because 4. cylinder wire are damaged. NGK mayby not the best choise, friend was buy and 2 was with deffect. What are the good 5 wire kit? Hope that not to much OT.My BG Familia FE3 project full spec and plans.
Mazdagirl, I'm surprised the NGK wire set was defective. They are a quality product, have a good reputation and are used by many here without problems. Is it possible that it was just one defective sample?
I use Magnecor spark plug wires. They provide excellent performance and are very long-lasting due to their construction but they are quite expensive compared to the NGKs. I don't know if they would be available in Estonia but in case your interested I'll provide the website:
More good wires what somebody use?My BG Familia FE3 project full spec and plans.
NGK or Magnacore. Pretty much anything else won't last long.'90 AWD Protege, full GTR drivetrain swap, ~320 whp daily driver, RIP, and
