Taylor Thundervolt Wires FTW
best sparkplugs for a protege
I've heard good thing about Taylor wires but haven't tried em myself.'90 AWD Protege, full GTR drivetrain swap, ~320 whp daily driver, RIP, and
i bought taylors when i first put the car together, they are still working fine. i like them.Escort GTR -- 11.87 @ 117.6 mph -- 320 HP / 325 Ft. Lbs. @ 23 PSI
I'm probably going to get blasted for this, but....I had good luck from Bosch wires back when I had a BG. Of course, I haven't used them in four years, so I can't really say what they're like now. I just know I didn't have issues back then.1995 626: daily beater, mostly stock. Future NASA racer?
Next up: Speed6 or RX-8
Originally posted by BG ALL DAY View Postso advance auto doesnt carry bkr7e anymore. autozone does not either where can i get this plug at any suggestions i still have napa and tropical on my list
part number 4644 they stock them at my local advance auto...Escort GTR -- 11.87 @ 117.6 mph -- 320 HP / 325 Ft. Lbs. @ 23 PSI
they're **** from what I've heard. NGK is suppose to be what the japan cars love1993 Protege LX-Midnight's shadow SOLD
ngk plugs, now can i run a base bkr5e-11 or do i need higher, i just running a stock 1.8l sohc...+ nowhere around here carries ngk or magnecor wires that i can find, im looking into some autolites or accells, anyone who has used these have and praise or complaints???Last edited by cory_creation; 04-24-2010, 10:11 PM.i am kakarot
You can get Magnecor wires from Corksport and NGK, wires and spark plugs, from: http://www.sparkplugs.com
autolites suck in the B8! I like the NGK iridiums. car runs much better on NGK's & the IR's lasted over 4 yrs!94 pro base model, all synthetic fluids, s/r struts, front & rear ebay upper strut bars,front & rear tie bar, ZX2 1" front swaybar, EGT 21mm rear sway bar, custom delrin endlinks front & rear, custom delrin rear swaybar mount bushings, EBC front blanks & redstuff pads, CS ss brake lines & dot 4 fluid, big drum brakes in rear (from ZX2, free parts), 2.25 custom exaust w/magnaflo oval muffler, 4-wire o2 sensor, custom ram-air, 4-wire BP tb, MSD super conducter plug wires, MSD Blaster SS coil, NGK iridiums,OEM weighted shift knob, ebay short shifter, bronzoil bushings, CS ss clutch line, custom air splitter, mx-3 recaro drivers seat, EGT foglight switch, 35w 5000k hi/lo hid's
soon:
lightened flywheel & clutch; in garage,
Miata Daisy's; after new tires
stay away from denso... they are real cheap...i put new ones in and the metal tab just fell off in my cylinder 3k mile after a rebuild. i had to do it all over again. i run bosch and have never had any issues, not only that but they last longer.
Originally posted by minnesotapjCost of your fancy German built sports car $35k
price of your fancy sun glasses to match your German built sports car $200 dollars
Getting beat by a second hand 20 year old Japanese 4 door... Priceless!The only bummer about the world ending is that you can't turn to the person next to you and say "WOW! Did you see THAT?!!"
