bpt pulleys
    bpt pulleys
    does the unduerdrive pulley of a bp fit on a bpt..someone tell me taht don't fit
    The Beast : sleeper 323 93 25th
    The Apprentice : Mazda 3 skyactiv 2012
    someone told you wrong then cause its the same block and head only big diff is intake and exhaust
    Check out the Pics
    http://www.wihandyman.com/forum/vbpi...?do=view&g=228
    Mazda's Rule Honda's Drool
      thanks...the bloc is the same anyway
        There are two different types of pulley though. Be sure to use the right one. One has a multi ribbed groove for the AC/PS and a v-belt groove for the alternator/water pump. The other pulley has multi-ribbed grooves for the AC/PS and the alternator/water pump. Both will bolt to the engine though, yes.
        Tyler has spoken
          that i know, i'm working at a mazda dealer
            Also, don't forget that there's 2 different size cranks. Small nose=22mm and big nose=27mm.
              but does the bp and the bpt can have the same crank?
                Yes. You have to measure them to see which 1 you have though
                  but why the don't put the same crank on alle bp for exemple..2 crank on the same motor
                    There was a year break, where 90-92 (or something) had the small nose crank, and then 93-94 had the large nose crank. As Chris said, you will need to take the pulley off of your BP and just quickly measure the crank to see if you got a big nose or small nose crank.
                        so wait, if you buy an imported gtx motor you could end up with a short nose crank?
                          yes.
                          they seem to mostly be long-nose style actually (not to be confused with big nose)... not the original small/short nose.
                            Originally posted by therieldeal View Post
                            yes.
                            ok, so i now know the long nose and big nose are different, but for realistic power levels is there any difference in reliability? are the long nose ones known to ever break?
                              thanks guys
