b6 disti on a bp?
    b6 disti on a bp?
    could it work for a temp replacement? my BP swap never came with one. the b6 disti is in the BP now, and is pulling a code 3. i know the disti is good too, ran fine on my b6.
    if it does work, then i'll change the plug on the harness, it looks like it's been repaired.
    thanks!
    JACK.
    I have a BP disty I could sell you fairly cheap
    ._________________________
      If the BP dist is the same as a BPT, they're different enough that she no gonna work. Mechanical advance in the b6, hall effect or optical and advance by ecu in the bp.
        this b6 disty isn't mechanical advance. its hall effect.
        JACK.
          I have been using a B6 dist in my BP swapped MX-3 for more than 2 years and it works just fine.
            The tabs are different, dunno how you want to mount it but with 1 bolt, it might leak. Can you even place it in the same position as the BP? If so, it should work as internally, they are the same.
