So my clutch disk grenade'd and i heard the mx6 clutch is slightly better. so i found a stock exedy clutch and wanted to make sure this is the correct one....
this the rite clutch?
you want a clutch for a 93-97 mx6 2.5 v6Escort GTR -- 11.87 @ 117.6 mph -- 320 HP / 325 Ft. Lbs. @ 23 PSI
ask tino, he did it toEscort GTR -- 11.87 @ 117.6 mph -- 320 HP / 325 Ft. Lbs. @ 23 PSI
Originally posted by therieldeal View Postyou want a clutch for a 93-97 mx6 2.5 v61993 Protege LX-Midnight's shadow SOLD
same clutch afaik... all the v6's use the same clutch.
and yes they all bolt to the BP flywheel. i'm using an ACT v6 pressure plate with a spec V6 disc.
the problem is it is not hard to kill a stock clutch with a mostly stock klde...Escort GTR -- 11.87 @ 117.6 mph -- 320 HP / 325 Ft. Lbs. @ 23 PSI
ya the disk blew up. its been slipping a little l8ly. well i had 5 ppl crammed into the lil 323 and when i was buzzing around town the clutch was slipping like bad. so i had to get home and dump everyone off.
well after dumping everyone off i started running the 2 miles to my place and then it blew. figured it was just heated up rly bad so it was brittle.
anyways, thanx guyz
to use the mx6 clutch do i also need the 2.5 v6 pp?
and about how much hp could the stock 2.5 clutch take?Last edited by MATT91GT; 08-16-2008, 12:33 PM.1994 Escort LX Wagon
2013 Hyundai Veloster Turbo
91 EGT - Junked May 2012
