Vj20 15psi?
    I'm on a VJ-20, stock GTX ECU and injectors (EGT FPR.) At 15psi from 4K RPM give or take, bleeding down to 12psi by 6k or so. My car ran lean, O2 voltage and EGT's were ugly. Sorry no wide band. I wound up getting more injector. Before, the o2's were dipping to .83 at 15psi, and by the time the creep went away at 6k it was still lean at .85 or so. After I'm seeing .90 (agian give or take depending on temp, gear, etc.) from 4k to fuel cut.
    Tuning by O2 voltage is old school and not at all a sciece, or even consistent. In my opinion a VJ-20 worked to its limit might not kill a motor runing GTX 330cc's. But, it definantly made me nervous. You should have slightly more headroom with a N/A FPR and a GTX bottom end.
    Also, an injector calculator http://www.rceng.com/technical.aspx. It's widely accepted a VJ-20 is good for 220 whp max. You'll see even 360cc's are too small.
      They tend to cut out past 20 psi and 5k rpm.
        i have the same problem, af ratio over 13 at 13 psi. that why the car its parked right not. dont want to blow the engine.
        2012 Kia rio
        2009 Nissan Frontier
        1997 chaparral 180LE
          Man, you guys are cautious.
            my a/f was 14-15 idle 15 cruising and 11-13 under boost at 11 psi on a vj20
              Originally posted by bcowie View Post
              After I pass 10 the AFR goes up to like 13,14+ with WOT which is not good. Just wanted to confirm its not a fuel injector limitation.
              change your fuel filter latley?
              eat me
                It's new, stock 323 fuel pump.
                  That could be yur problem. Your stock furl pump might not be able to keep up. Investing in a Walbro would be a good idea.
                    actually i said filter
                    a filter can allow the proper PSI but not a high enough gal per minute flow
                    eat me
                      I know, the filter is new the fuel pump is stock 323.
                        what is your air fuel ratio at idle?
                        do you own a wideband and pyrometer?
                        eat me
                          Wideband only
                          15 at idle
