Me and a friend were thinking it could be done..then I was talking about it on mazdas247 and they said that people over here have done it. So im just wondering; What all does it take to do it, what are the down sides, what are the up sides.
BP head to B8 block
you need all the timing belt/water pump stuff, an some other odds and ends
downsides... low compression like a GTX. the sohc pistons are dished.Escort GTR -- 11.87 @ 117.6 mph -- 320 HP / 325 Ft. Lbs. @ 23 PSI
i doubt it, they are probably the sameEscort GTR -- 11.87 @ 117.6 mph -- 320 HP / 325 Ft. Lbs. @ 23 PSI
Yeah my intuition says they're probably the same, maybe even the same as GTX pistons, minus the pressed vs spring clip, but that wouldn't really mean they'd have to do a big design change would it? I have been wondering for a while if there's any way to substantiate it though.
But on topic, sure you can do it, its bolt on.
downsides are the low comp, upsides would be the lighter crank and maybe opportunity to put more PSI in teh cylinders, but ultimately you won't make more power. I'm gonna be boositng on SOHC pistons at first, if I ever get there
NickLast edited by jumpncrash; 01-22-2009, 06:14 PM.Posted By: Wheresthericego
all the con. rods are the same in the SOHC or DOHC B6/BP's cause the hieght of the blocks(crank to head) and stroke are all the same. The only different rods are the B6T rods, which are a little stronger, and the GTR's rods which are much stronger. all interchange."See that car, in the 80's that car was deadly." Random man to his son while passing the GTX in a parking lot
-93' Mazda Miata, half caged
-09' Mercedes C63 AMG
You will need the intake and exhaust manifold. I have a intake mani you can get cheap and you could pick it up to save on shipping...I live my life a quarter pounder at a time. And for those 500 calories or more, I'm free. I need FRIES! Two of them. The big ones. Oh, and I need them tonight. You're lucky the double shot of BBQ sauce didn't blow the seam on your nugget box. There she is, 2 pounds of pure beef. My dad ate it in 9.0 seconds flat. Check it out, it's like this. If I lose, winner takes my happy meal. But if I win, I take the burger and the toy. To some people, that's more important.
._________________________
B8/BP rods are the same. I had BP and B8 rods side by side. B8 pistons are pressed on, while BP pistons use C- clips. Thats the difference. B8 pistons don't have the groove for the C-clip.No car! I soldz it. Now I have a truck. I like it, but apparently it has a hard time keeping up with a slightly modified 4WD protege with half the hp. Neat.
Originally posted by nerd racing View PostI believe the B8 pistons are made of a weaker material as well
The rods are different in that the small end (pin/piston end) is smaller in inside diameter for fitment of the pressed-in pin... either wise the size and length are the same. AND NO, they won't fall out if you put a turbo on it... if you're raising the cylinder temperature high enough for the pin to fallout you're gonna have bigger problems before that even happens. PLUS you're running too lean and you're FIRED from tuning!
You could probably machine the small ends to fit the floating pin but why bother, you're also probably need an oil hole in the top of the rod to lubricate the pin and you'll be taking away material from the small end possibly making it weaker, depending on how much you have to machine out.
Now you've been edumacated...
Member of MX-3.com
"Do it ONCE, do it RIGHT!"
