I am starting to (try to) work on my car myself and am stuck on an embarrassingly simple problem... I don't know what model my engine is, so I can buy the right plug wires.
There is no sticker with this info to be found under the hood or by the door.
No problem, I thought. I'll find an online VIN decoder and that will tell me.
Well, that didn't work. It couldn't tell me what my engine size was (it did provide a little info from the VIN, but not the engine size).
Here is the VIN, in case some guru can decode it manually: JM1BG2236R0787816
My car is a 1994. It says "16 Valve", so based on a shop manual I found, I know its not a SOHC 1.6. So as far as I can tell, it is either a SOHC 1.8, or a DOHC 1.8 . . . ??
Any suggestions as to how I can tell?
