It's an Automatic 94 DX..
1- I replaced the water pump and thermostat and the radiator is almost new, also the fluid. The car's temperature is like 4mm above the middle of the temperature gauges. To me, it looks like its overheating. but Is that normal?
2- (I jumped TEN and GND already) At what RPMs should the car idle when it is in P??Mine idles at around 1150rpms(between the 1000 and 1250rpm lines), it goes down to 1000rpms at then it goes back up to 1150 every like 2 seconds. Also, when I put it in drive it idles at 500rpms. I checked the air screw thingie and if i make it idle at 750's it'll idle at around 1500rpms when is parked. What the hell??
3- Where EXACTLY is the transmission filter??
4- When I drive at above 35mph I start hearing a sound coming from under and front of the car like if metal was rubbing on something. I dont really know what it is.. Any ideas??
Thank You.
Thank You.
