i have just purchased a 93 mazda protege dx 5 speed and i have no fuel pressure until i jump them two pins gnd fp i hear the pump kick on and have 45psi pressure still wont start?
alldata states with no vacuum to pressure regulater should be 38 to 46 so my 45 psi is in spec also correct?
it says on alldata pro if the pump kicks on i check it its 12+ volts i have 12 volts what is before the jumper thats not letting it turn fuel pump on?
i have changed maf and fuel pump relay in underhood box with my current running 92 mazda protege dx 5 sp still no luck checked the fuse for the fuel pump in same box and checked all the ones in the front driver kick panel
thanks for any suggestions
